Re: [Nagios-devel] [PATCH] Continuation lines
* Ethan Galstad [2007-12-13 11:08]:
> Holger Weiss wrote:
> > Thanks a lot, though the following line is now appended if and only if
> > two backslashes are used. From the original function, I assumed the
> > idea was to append the following line if the current line ends with a
> > backslash _unless_ this backslash was escaped using another backslash.
> > IMO, doing it this way round would be more intuitive as it's a common
> > way to implement continuation lines.
> I'll get this changed to work as you mentioned. Thanks!
Works fine now, thank you!
Holger
