Andreas Ericsson wrote:
> Andrea Gabellini wrote:
>> Hi,
>> I'm using various solaris versions, from 5.7 to 5.10.
>> An usable header file is iso/limits_iso.h except for solaris 5.7 where
>> the header fiele is limits.h.
>> As a workaround I'm using, in cgi/getcgi.c:
>> #ifndef INT_MAX
>> #define INT_MAX 2147483647
>> #endif
> A more portable way is to write
> #ifndef CHAR_BIT
> # define CHAR_BIT 8 /* true for any system created post-woodstock */
> #endif
> #ifndef INT_MAX
> # define INT_MAX (1 #endif
gaah! dangerous to write code in emails just after lunch.
#define INT_MAX (~(1 << (sizeof(int) * CHAR_BIT) - 1))
is the correct way. Sorry if I caused any confusion.
OP5 AB www.op5.se
