[Nagios-devel] mysql enabled - can't see data on web page
I'm seeing a similar problem viewing service trends, though everything else
seems to be fine. I first noticed it with 1.0a5. I'll dig a little deeper.
-----Original Message-----
From: David Edward Shapiro [mailto:[email protected]]
Sent: Tuesday, March 05, 2002 4:26 PM
To: '[email protected]'
Cc: '[email protected]'
Subject: [Nagios-devel] mysql enabled - can't see data on web page
(netscape plugin)
I enabled mysql support for the full monty accept objects. If I look in the
database nagios at its tables, which I created with the
contrib/create_mysql, I see data, but if I go to the web page and try to
view the data, a netscape plug-ins box pops up and tries to have me download
a plugin called NPNetRecall.jar. It is only compatible with netscape 4.x
though, and I use netscape 6. The page also says:
It appears as though you do not have permission to view information for any
of the services you requested.
Original poster: avid Edward Shapiro [mailto:[email protected]
