Re: [Nagios-devel] Problem init.d script
1. I won't believe that "The Noob" is written in your birth certificate
2. x-posting won't help you getting usefull answers
3. after deciding wich mailing list you want - give us more informations
(do you use 'restart', 'reload', 'magic')
4. it might be the known behavior, that nagios 2.x won't exit correctly
if a hostcheck is just running - have a look in your nagios.cfg about
host_check_timeout and set a sleep "that_value +1" between stop and
start of your init script
@Lists: Sorry for x-posting again ;)
The Noob schrieb:
> Hello all,
> I have a problem with the start script (/etc/init.d/nagios)
> Sometimes, when I stop or restart Nagios, I have a timeout. Then
> Nagios crash and it does not restart correctly and starts with the old
> configuration.
> kill -9 permits to stop all processes nagios.
> What can I check on my server to fix this bug ?
> Nagios Version is 2.9.
> Thanks for your answer
> Best Regards
> TheNoob
> This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
> Don't miss this year's exciting event. There's still time to save $100.
> Use priority code J8TL2D2.
> http://ad.doubleclick.net/clk;198757673 ... om/javaone
> Nagios-devel mailing list
> [email protected]
