Thanks - will be in CVS soon.
On 20 May 2005 at 14:14, Stanley Hopcroft wrote:
> Dear Folks,
> Please find below a patch against the 2.x CVS of the last 10 days.
> The object is embedded Perl support.
> The intent is to avoid the
> 1 surge of memory use by the Nagios process
> 2 increased rate of memory use by the Nagios process
> after sending a hangup signal.
> Prior to this patch, I would reconfigure and then activate the changes
> by a restart (stop/start).
> The patched code does not call init_embedded_per() and
> deinit_embedded_perl() when sigrestart is true (set by the HUP
> sighandler in utils.c).
> A patched copy has been running here for the last 24 hours and been
> hupped a few times in that period.
> Yours sincerely.
> tsitc> diff -u nagios.c.orig nagios.c
> --- nagios.c.orig Thu May 19 22:25:29 2005
> +++ nagios.c Thu May 19 22:28:11 2005
> @@ -576,7 +576,8 @@
> /* initialize embedded Perl interpreter */
> #ifdef EMBEDDEDPERL
> - init_embedded_perl(env);
> + if(sigrestart==FALSE)
> + init_embedded_perl(env);
> #else
> init_embedded_perl(NULL);
> #endif
> @@ -721,7 +722,8 @@
> close_command_file();
> /* cleanup embedded perl interpreter */
> - deinit_embedded_perl();
> + deinit_embedded_perl();
> /* cleanup worker threads */
> shutdown_service_result_worker_thread();
> tsitc>
Ethan Galstad,
Nagios Developer
Email: [email protected]
