I have a strange problem with the nagios web page display. When I first installed nagios on my monitoring machine, I defined a few hosts and services and everything was working just dandy. I have now added a whole pile of other hosts & services but when I view, say, the services web page it will only display the originally defined services. If I click Services in the menu several - sometimes many - times, it will eventually display everything. There are even a few services which have been added to the originally definitions which exhibit the same thing. Same thing when I try to view the hostgroups or hostsgroup detail. It often takes several clicks to get a display.
The summary grids at the top of the page also display OK - showing host/service status details correctly (but not all the time
I have tried 3 different browsers on various workstations, so I don't think it is a browser issue. If I am right in that assumption, then it has to an Apache or Nagios (or php?) problem. Anyone else seen this? Any ideas as what is going on?
By the way, even viewing from the local machine shows the same symptons.
My current setup is:
OpenSuSe 11.3 - fully patched
Nagios 3.2.3 - with current plugins
Apache 2.2.15
php 5.3.3
So, bin it and start again
