Re: [Nagios-devel] NDOUtils configure error on CentOS x86_64
On 8 Jan 2008, at 14:42, Herbert Straub wrote:
> The specification of the configure options --with-mysql-lib and
> --with-pgsql-lib does not work. The mysql library path cannot found.
Does this patch work for you? It uses mysql_config to work out the
appropriate flags.
http://altinity.blogs.com/dotorg/2007/0 ... qlcli.html
Ton
http://www.altinity.com
UK: +44 (0)870 787 9243
US: +1 866 879 9184
Fax: +44 (0)845 280 1725
Skype: tonvoon
