Re: [Nagios-devel] process_check_result_file does not delete files
CVS code from pserver cleans the files. But the CVS-Tarball does not -
does the daily cvs tarball creation work?
Flo
Ethan Galstad schrieb:
> IIRC, I forgot to remove some debug code from a CVS commit last week or
> the week prior. That code prevented the check results from being
> deleted so I could examine how things were working. Recent CVS source
> code should fix this problem. Hope that helps.
> Hendrik Baecker wrote:
>> Please drop last patch... didn't read the man open right... sorry for that.
>> After cleaning up the checkresult dir nagios creates all needed files
>> (cXXXXXX + cXXXXXX.ok) properly.
>> @florian
>> can you please have a look at your checkresult spool dir and tell us if
>> there is a *.ok file for each cXXXXXX file?
>> In case that not please try this patch to get an error message to logs
>> and console to determine why nagios could not create that ok file.
>> Regards,
>> Hendrik
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> Nagios-devel mailing list
> [email protected]
