Re: [Nagios-devel] Running 6K hosts
It sounds like a lot more invasive changes are required to give a
"tremendous" speed bump compared to the handful of lines required for a
mere "dramatic" increase. :)
On Tue, 8 Feb 2005, Andreas Ericsson wrote:
> Ben wrote:
> > A quick glance at the code makes it look like all the xodtemplate
> > functions spend most of their time list walking. Converting from a list to
> > a tree/hash should dramatically speed things up.
> Forget hashes. If objects were properly indexed in internal tables, this
> would be a much simpler issue where only host-names have to be hashed.
> Services could then be organized in a 3D table indexed by size_t
> host_id, which would reside in the host object struct (in running
> config, that is). The one-time load penalty would be slightly higher,
> but not necessarily very much since the internal tables really don't
> have to bother with alphabetical sorting and such.
> If one wants it even faster, it would be simple to put all objects
> referenced by others into such tables. For instance, a service object
> could have a serviceextinfo_id variable so as to quickly locate it in a
> map. With only very minor modifications to the CGI's and the daemon
> (printing total number of each object type at the top of objects.cache
> so it doesn't have to bother with reading, counting, allocating,
> indexing and tabulating in separate passes), one would notice a
> tremendous speedup.
> > On Tue, 8 Feb 2005, Jason Martin wrote:
> >>I'm looking ahead to running a 6K host / 60K service distributed
> >>Nagios setup reporting up to a central Nagios host.
> >>The test procedure was to write a config file consisting of X
> >>hosts with 10 services per host.
> >>On a 2 proc 2Ghz Intel machine, the preflight time for 1.1 and
> >>2.0cvs comes out as:
> >>Hosts v1.1(s) v2.0(s)
> >>100 0 1
> >>400 5 4
> >>500 7 6
> >>1000 23 23
> >>2000 149 117
> >>3000 321 251
> >>4000 526 431
> >>5000 760 651
> >>6000 1034 912
> >>The profile for the preflight is:
> >>Each sample counts as 0.01 seconds.
> >> % cumulative self self total
> >> time seconds seconds calls ms/call ms/call name
> >> 84.24 4.33 4.33 5502 0.79 0.79 xodtemplate_find_service
> >> 7.78 4.73 0.40 1 400.00 449.66 xodtemplate_sort_services
> >> 4.09 4.94 0.21 1 210.00 210.00 pre_flight_check
> >> 0.78 4.98 0.04 5501 0.01 0.01 find_service
> >>It looks like xodtemplate_find_service is still taking up a log of time. Can
> >>anything be done to speed it up? Otherwise it looks like 6K hosts is going to be unatainable.
> >>Thanks,
> >>-Jason Martin
> >>This message is PGP/MIME signed.
> > SF email is sponsored by - The IT Product Guide
> > Read honest & candid reviews on hundreds of IT Products from real users.
> > Discover which products truly live up to the hype. Start reading now.
> > http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Lead Developer
> [email protected]
