Hi Tom,
Tom Sommer schrieb:
> Since this suggestion seems to have some backing, I thought I would
> forward it to the devel list.
> Note that several other monitoring systems provide the mentioned feature.
> The complete thread can be found in the users list.
> ---------------------------- Original Message ----------------------------
> Subject: Retry interval on hard states
> From: "Tom Sommer"
> Date: Fri, March 7, 2008 14:44
> To: [email protected]
> Hi,
> I wish to setup the following check interval:
> Check the service every 5 minutes
> -> If down then check the service every 1 minute for 3 minutes/times
> -> If still down, notify and continue to check the service every 1
> minute until it recovers.
> I'm having a few problems with the last condition. Basically once the
> notification is sent, Nagios seems to revert to the "normal" check
> interval, which is 5 minutes - resulting in a substantial delay for the
> recovery notification to be sent.
> My settings are:
> max_check_attempts 3
> check_interval 5
> retry_interval 1
> Did I miss anything or is the above simply not possible?
> Using 3.0rc3
You could solve your wish via an event_handler. Let it trigger an
external command to change the normal_check_interval.
More info see here:
http://www.nagios.org/developerinfo/ext ... and_id=109
http://www.nagios.org/developerinfo/ext ... and_id=110
Regards,
Hendrik
