Please don't top-post. It makes it impossible for mail-archive readers
to follow the flow of the conversation.
[email protected] wrote:
> The idea was to only use it for notifications only. In a reasonably
> funcional environment notifications should'nt be sent often enough to
> become a performance killer should they?
That depends. With recurring notifications, a lot of checks are made
against timeperiods to determine if a notificaiton should be sent at
all, or when it next should be sent if it shouldn't be sent right now
(etc, etc). If you implement this, your program will have to be able
to communicate answers to the following questions:
1. Is now a good time?
2. Are there any good times at all?
3. When is the next good time?
4. When does the next good period stop?
That might look trivial, until you think about it and realize that
you need to properly handle the case where the answers to 2, 3 and 4
change between two runs of the timeperiod check. You also need to
devise a way for the plugin to communicate dates and timestamps back
to Nagios in a way that makes sense and doesn't break down.
It would be far, far simpler to implement this in the notification
script itself, where the check only happens in case Nagios has
decided that the notification really has to be sent. For that case,
you only have to answer question 1 above, which is the trivial one.
> /M
> -----Original Message-----
> From: Andreas Ericsson [mailto:[email protected]]
> Sent: den 21 november 2008 16:34
> To: Nagios Developers List
> Subject: Re: [Nagios-devel] Command to replace timeperiod
>> I've been considering implementing the use of "standard" Nagios
>> commands to make it possible to incorporate any kind of calendar
> functionality.
>> Hosts and services could have an option
>> "notification_timeperiod_commands" or something like that.
>> Good or bad idea?
> Bad. It's a performance killer for anything but very small environments,
> as timeperiods are checked every time a check is run, or a notification
> is sent, or a check is rescheduled, or... etc.
> If you need something like this, submit a patch to let NEB-modules
> replace the timeperiod functionality and then let that NEB-module check
> things up in a database/external file/whatever.
OP5 AB www.op5.se
