Re: [Nagios-devel] Nagios check_ping High RTA
[email protected] wrote:
> Hi
> a) Whenever i do normal ping(from shell)of a host takes less than 1ms, but when
> i do ping using check_ping plugin it gives me 20ms and some times its shows less
> than 1ms.
> So there is an fluctuation happening in nagios check_ping plugin.
Normal ping measures round trip time, whereas check_ping measures round trip time
*average*. Normally when a host that hasn't been connected to for some time is
about to receive a packet, routers and switches have to resolve the hosts ARP
address, which takes 5-20ms in a local network. Since check_ping only sends 5
ICMP ECHO requests by default, the (much) higher initial round trip time plays
a large relative role for it.
> b) Is there any way to avoid those fluctuation?
Increase the ARP cache size on your switches.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
