RE: [Nagios-devel] Disable host checking ?
> -----Original Message-----
> From: [email protected] [mailto:nagios-devel-
> [email protected]] On Behalf Of Marco Borsani
> Sent: Wednesday, March 23, 2005 10:15 AM
> To: [email protected]
> Subject: [Nagios-devel] Disable host checking ?
>=20
> Hi all
>=20
> I know that setting to "0" the checks_enabled variable into hosts.cfg
file
> I
> will stop the host checking.
>=20
> If I perform via CGI the same action (pressing "Disable checks of this
> host") WHERE nagios will "write" this setting ?
It's changed only in its internal, memory based, representation of the
objects. If you have host and service retention enabled then these
changes are written to the status.sav file and reloaded when nagios is
restarted. If you do not retain status then the change will be lost when
nagios is restarted.
=20
> I saw that nothing changed into hosts.cfg file.
Nagios will never modify any configuration file.
=20
> I have same doubts for other actions performed via CGI.
If you expand on them perhaps we can address them.
Marc
