Re: [Nagios-devel] nagios-cvs: Too many open files?
> -----Original Message-----
> From: [email protected] [mailto:nagios-devel-
> [email protected]] On Behalf Of Ethan Galstad
> Sent: Wednesday, February 07, 2007 10:27 AM
> To: Nagios Developers List
> Subject: Re: [Nagios-devel] nagios-cvs: Too many open files?
>=20
> >> [email protected]] On Behalf Of Gerd Mueller
> >> Sent: Wednesday, February 07, 2007 9:40 AM
> >> Subject: [Nagios-devel] nagios-cvs: Too many open files?
> >> Hi,
> >> my systems are sometimes running out of open file handles. Is this
> >> normal for a normal nagios process:
> >> nag01:~# lsof | grep "/tmp/nagios" | wc -l 41631
> > I would say no, since nagios doesn't usually open files in /tmp.
> > [root@dc1 root]# lsof | grep "/tmp/nagios"
> > [root@dc1 root]#
> > Is that the location of temp_file in nagios.cfg? Is the command
shown in
> > lsof for those processes nagios or some plugin? I suspect that it's
> > going to be some misbehaving plugin that you're using.
>=20
> Actually, Nagios has a new temp_path option that defines a directory
> where Nagios will create temp files. Host and service checks in
Nagios
> 3 write their output to temp files - that's how the plugin output
length
> restriction was done away with.
Ah, yes, I remember reading that now. Thanks for the clarification.
Marc=20
