--_000_E675211DF23BC34BBD0B455DB3AF408741A320C6MBX02ldschurcho_
Content-Type: text/plain; charset="iso-8859-1"
I have one question and one observation in addition to what I already said.=
Question:
In the case of the web server and nagios being on the same system, how much=
is an fsync() really going affect the performance of the system? Can someo=
ne "quantify" the impact of a single fsync? (I guess that is technically a =
second question.) If it were to do a sync() (where all the open files are c=
hecked to ensure that they are sync'd) instead of an fsync(), I would defin=
itely agree - much bigger impact. But, the single fsync at the end of writi=
ng a file should not be of any real significance, except in the case where =
it means that the data is actually there where it should be if it *is* done=
(e.g. my case).
Observation:
I think that the retention.dat and other files that are important to retain=
across crashes would definitely benefit from the fsync. Though nagios woul=
d still work across such a failure, I would rather that data be preserved p=
roperly, especially when we have a retention.dat file that is 40MB and the =
rescheduling, etc. would be handled so much more effectively. So for what i=
t is worth, I think it important that those files be fsync'd.
Thanks.
Cary
________________________________________
Sent: Friday, August 07, 2009 2:30 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Possible patch to cure CGI's not finding data f=
or objects in status.dat
Cary Petterborg wrote:
> In response to your request for details of our system: We are running
> SuSE 9 writing to a Rieser FS (with a separate web server reading the
> status.dat, etc. from an NFS mount off the main Nagios server). Our
> status.dat file is 37MB, and objects.cache is 32MB. If you need more
> details than this, please let me know what you need.
I blame NFS. Don't use it for sync()-sensitive data, as caching happens
on multiple levels. The patch hurts the normal case (webserver on same
system as Nagios) though, so I'd prefer if it wasn't applied.
> I may be wrong in this next information, but I did homework on it
> before proceeding to try to implment the fix on our system, and I'm
> taking the information from what I found. The fsync() call is the
> more important function call in the fix. fclose() almost always
> guarantees fflush(), but it doesn't guarantee that it will be written
> to the disk immediately, especially if the program doesn't exit.
It doesn't have to be written to disk. After the fclose() the kernel
will cache the data so the next reader will still see the full file
contents no matter if it's actually committed to disk or not.
fsync() and fflush() are primarily meant to make sure data stays
intact across power outages.
NFS breaks this sometimes. CIFS is a better option, I think.
What happens if you use a webserver on the same host?
What happens if you use CIFS instead of NFS?
OP5 AB www.op5.se
on peace.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus =
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you
...[email truncated]...
Original poster: br
