Thomas Stolle wrote:
> Dear List,
> 1.) sporadic I get negative values for check execution time in
> "performance info" of nagios3. I can not reproduce this behaviour.
> Check Execution Time: -1167735239.71 sec 5.01 sec -1307653.816 sec
> Check Latency: 0.00 sec 162.52 sec 143.760 sec
> Percent State Change: 0.00% 79.47% 0.88%
> 2.) Even with disabled hostchecks (no check_command in host definition)
> the hostcheck-counter in "performance info" of nagios3 starts counting.
> I can not find any entries of hostchecks in the logs. Thats why I think
> the checks were not really executed. Also the hostcheck execution time
> is very short (0.05 sec) .
> I don't know if this is a bug, if it is new in Nagios 3 or if the same
> behaviour can be found in Nagios 2, cause I can only compare to
> nagios1.2, which does not offer performance info for hostchecks.
> Thomas
Any chance you can grab a copy of the status.dat file when you see these
values? I'd like a chance to look at the raw file to see what's going
on (CGI problem, status data problem, etc.). Thanks.
Ethan Galstad,
Nagios Developer
Email: [email protected]
