Re: [Nagios-devel] Nagios external commands (2)
Tobias Mucke wrote:
> Hi Andreas,
> thanks for your reply.
> What I want to achieve is to write a program which is able to write
> External Commands into the Nagios External Command Interface. Is there
> such a program yet? I did not found one.
> But I don't want to hardcode all the External Commands and the needed
> options, escpecially if there are new External Commands from time to
> time or existing ones are changing, I don't want to change my code.
> So my first step is to describe all external commands in a XML
> structure. Second step will be to write code using this XML file to
> understand which commands are possible and which options are needed,
> so it can check the input from the user and write the correct command
> into the pipe.
Well, there are easier ways to do that than putting all of it in XML,
although I applaud any effort that there's even the slightest chance
that anyone will use.
> Working with the External Commands documentation at nagios.org I got
> the impression that it is written manually and stored in some kind of
> content management system.
True. This must be so, or the docs might not match the reality in the
code.
> With a XML file describing the Nagios
> External Command Interface you could generate the documentation e.g.
> by XSLT.
> Why should you do that? Because it would be possible to send patches
> for the documentation in a program understandable diff format.
But it already is. The program creating such program understandable diffs
is called (surprise, surprise) "diff". The program that understands those
diffs is called "patch". ;-)
Seriously though, like I said above, the docs need to be maintained along
with the code, or the doc-to-code relation might get broken for a certain
revision of either.
> Future use, e.g. for XML-RPC or some other sort of interface:
> Thinking of a distributed monitoring environment you need a central
> console for it. We have such a setup here and it works fine. We are
> using the webinterface of the central monitoring system right now.
> This system also does notifications and escalations.
> Actually we are going to work on a concept for an even more
> distributed environment. Right now all distributed monitoring systems
> are located at one datacenter location. But we want to roll out Nagios
> to other datacenters at remote locations too. The idea is to give the
> remote datacenter as much as autonomy as possible e.g. keep
> notifications local at each location.
Sounds like a good idea. I'd use a NEB to propagate the commands if I
were you, or a separate program altogether.
> Nethertheless we want just one central console to control the Nagios
> infrastructure, for example to enable / disable notifications. So you
> have to control Nagios by an interface you can send commands to from a
> central system. These commands should be checked if they are correct
> before they are passed into the pipe.
Why? They must still be checked for correctness inside Nagios. Adding
another point of failure might mean you get bitrot in the xml-doc, so
your commands (which nagios would understand perfectly) don't go through.
Otoh, if you update the xml-doc prematurely, you would get "OK" from the
XML validation thingie and then Nagios wouldn't grok it anyways.
> Other projects, e.g. Xen, are solving this by a XML-RPC interface
> which is easy to implement.
> Actually I don't know the NEB and its possibilities but I thought the
> PIPE will vanish into thin air in Nagios 3.0. So this is not a
> bottleneck anymore.
"pipe" is not an acronym, so no need to capitalise it.
The FIFO stays. It'll no longer be used for child processes to pass service
results to the grand-parent, but it'll still be used for external commands.
However, assuming your implementation doesn't touch the nagios core, it won't
be a problem since you can then convert the XML-command into a format that
nagios groks, after having stripped the XML overhead.
OP5 AB www.op5.se
Tel: +46 8-230225
...[email truncated]...
