Applied. Thanks.
On 11/23/2012 03:09 PM, [email protected] wrote:
> From: Robin Sonefors
> The functionality to do so is right there, and the value of this
> information is relatively high, so please print it.
> Signed-off-by: Robin Sonefors
> base/commands.c | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/base/commands.c b/base/commands.c
> index b7b8ff4..7140283 100644
> --- a/base/commands.c
> +++ b/base/commands.c
> @@ -252,8 +252,8 @@ int launch_command_file_worker(void) {
> command_wproc->sd = sv[0];
> ret = iobroker_register(nagios_iobs, command_wproc->sd, command_wproc, command_input_handler);
> if (ret - logit(NSLOG_RUNTIME_ERROR, TRUE, "Failed to register command file worker socket %d with io broker %p\n",
> - command_wproc->sd, nagios_iobs);
> + logit(NSLOG_RUNTIME_ERROR, TRUE, "Failed to register command file worker socket %d with io broker %p: %s\n",
> + command_wproc->sd, nagios_iobs, iobroker_strerror(ret));
> goto err_ioc;
> logit(NSLOG_INFO_MESSAGE, TRUE, "Successfully launched command file worker with pid %d\n",
OP5 AB www.op5.se
on peace.
