Re: [Nagios-devel] Checking for required elements
>> Finally in trying to duplicate this I was trying to come up with a
>> minimal
>> config and found one that would cause a Segmentation fault during
>> checking
>> contacts. Here it is:
>> define contact {
>> contact_name test
>> service_notification_commands command
>> host_notification_commands command
>> define command {
>> command_name command
>> command_line echo test
>> define host {
>> host_name host
>> max_check_attempts 1
>> define service {
>> service_description service
>> host_name host
>> check_command command
>> max_check_attempts 3
>> Thanks for your great work,
>> -Shad
> I tested this tiny config and it worked okay - got warnings about
> missing timeperiods and it didn't segfault. Try the latest CVS when you
> get a chance to see if that fixes any problems you were having.
If you can give some short instructions I'll provide a backtrace if you
think it will help.
-Shad
