Re: [Nagios-devel] ndoutils compilation problem on Solaris 10
Another error ...
gcc -g -O2 -DHAVE_CONFIG_H -D BUILD_NAGIOS_2X -o ndo2db-2x ndo2db.c=20
dbhandlers-2x.o io.o utils.o db.o -lnsl -lsocket -lmysqlclient
ndo2db.c:14:20: mcheck.h: No such file or directory
mcheck doesn't exist on Solaris ?
I have tried to comment #define DEBUG_MEMORY 1
After i have :
Undefined first referenced
symbol in file
ceil utils.o (symbol belongs to=20
implicit dependency /usr/lib/libm.so.2)
asprintf dbhandlers-2x.o
ld: fatal: Symbol referencing errors. No output written to ndo2db-2x
collect2: ld returned 1 exit status
I have corrected "ceil" problem by adding $(MATHLIBS) in src/Makefile=20
to :
ndo2db-2x: ndo2db.c $(NDO_INC) $(NDO_OBJS) $(COMMON_INC) $(COMMON_OBJS)=20=
dbhandlers-2x.o
$(CC) $(CFLAGS) $(DBCFLAGS) -D BUILD_NAGIOS_2X -o ndo2db-2x=20
ndo2db.c dbhandlers-2x.o $(COMMON_OBJS) $(NDO_OBJS) $(LDFLAGS)=20
$(DBLDFLAGS) $(LIBS) $(SOCK
ETLIBS) $(DBLIBS) $(OTHERLIBS)
Damien
Le 14 avr. 06, =E0 20:54, Damien Basti=E9 a =E9crit :
> Hi,
> I have corrected the problem by adding in io.c file :
> #define SUN_LEN(ptr) ((size_t) (((struct sockaddr_un *) 0)->sun_path)=20=
> + strlen ((ptr)->sun_path))
> Damien
> Le 14 avr. 06, =E0 18:25, Damien Basti=E9 a =E9crit :
>> Hi,
>> I tried to compil ndoutils with my Solaris 10 box, and i have these=20=
>> following errors :
>> # make
>> cd ./src/; make ; cd ..
>> make[1]: Entering directory=20
>> `/export/home/compilation/ndoutils-1.3.1/src'
>> gcc -g -O2 -DHAVE_CONFIG_H -c -o io.o io.c
>> gcc -g -O2 -DHAVE_CONFIG_H -c -o utils.o utils.c
>> gcc -g -O2 -DHAVE_CONFIG_H -o file2sock file2sock.c io.o utils.o =20=
>> -lm -lnsl -lsocket
>> Symbole premi=E8re r=E9f=E9rence
>> non d=E9fini dans le fichier
>> SUN_LEN io.o
>> ld: fatal : Erreurs dans le r=E9f=E9rencement des symboles. Aucun=20
>> r=E9sultat n'a =E9t=E9 =E9crit dans file2sock
>> make[1]: *** [file2sock] Error 1
>> make[1]: Leaving directory=20
>> (Sorry i have french box)
>> It seems that SUN_LEN doesn't exist on Solaris...
>> Anyone have a small patch ?
>> Thx in advance,
>> Damien
>> This SF.Net email is sponsored by xPML, a groundbreaking scripting=20
>> language
>> that extends applications into web and mobile media. Attend the live=20=
>> webcast
>> and join the prime developer group breaking into this new coding=20
>> territory!
>> http://sel.as-us.falkag.net/sel?cmd=3Dl ... dat=12164=
2
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
> Damien Basti=E9
> Administrateur Syst=E8me et R=E9seau.
> BRAINTEC
> 9 rue Santos Dumont, 75015 PARIS
> T=E9l : 33 156085200 - Fax : 33 156085239
> http://www.braintec.fr
