Re: [Nagios-devel] [Nagiosplug-devel] some addition to nagios I'm
William,
This sounds very interesting but should go to nagios-
[email protected] instead.
Ton
On 15 Jun 2006, at 22:28, william(at)elan.net wrote:
> I'm working on some additions to nagios code as part of my current
> project (actually most of it is already done). If you'd like to see
> any/all of this submitted as patches for inclusion in your main
> code, let me know:
> 1. Addition of extinfo structures for hostgroup and servicegroup
> (mostly duplicated structures & supporting code for
> service_extinfo),
> the config for them are [not surprisingly] hostgroupextinfo and
> servicegroupextinfo. I only need to use hostgroupextinfo myself
> so servicegroupextinfo code will not be well tested.
> 2. Additional target_frame field in all extinfo structures and in
> their config file that as you could guess is to be used to
> overwrite default "target=_blank" when using extinfo urls.
> 3. Support for having multiple hostextinfo and serviceextinfo for
> the same host/service. This would result is more then one icon
> being displayed (makes having both notes_url and action_url
> kind-of useless, but oh well...). This is probably more
> controverseal extinfo addition then the above as it changes
> expected error-condition behavior.
> 4. New status types "HOST_DISABLED" and "SERVICE_DISABLED" that
> with status.cgi shows up as separate field in status totals
> and not counted in "All problems". This status is actived
> when you manually disable active checks, i.e. expect it to be
> down for considerle period or it maybe service that was not
> up in the first place (i.e. same services specified for hostgroup
> and not every host has all of them). For my scenario I wrote it
> so that disabling host would automaticly cause all services for
> it to be seen as disabled (even if you did not actually disable
> them), many of you probably dont want that. BTW - this addition
> I've had in my production nagios for several months now and have
> been backporting patch from 2.1 to 2.2 and now 2.3 code. This
> likely even more controversial then all extinfo changes...
> Note that most of my current code additions are done like:
> #ifdef SUPPORT_DISABLE_STATUS
> ..code
> #iendif // SUPPORT_DISABLE_STATUS
> For real patches to main code you probably want those ifdef gone
> but possibly they could be converted to regular 'if' checking
> that particular configuration is activated.
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
