Out of curiosity (not because I know better) what about the 'obsessing'
logic doesn't handle this for you?
On Thu, Dec 04, 2003 at 07:00:14PM -0500, [email protected] wrote:
> I sent in this post almost a month ago. I'm wondering if anyone thinks it's
> a feature worth implementing. I'm not running the latest HEAD (I'm at v1.1
> right now) but I'd be willing to setup a test instance with the HEAD, make
> the alterations, etc. - if it's going to be merged into the codebase.
> It's pretty hard-core when it comes to the nitty gritty of the notifications
> logic. It's taken me some time just to figure out.
> "Computer science is as much about computers as
> astronomy is about telescopes" -- Edsger Dijkstra
> Anthony Tonns, UNIX Administrator - [email protected]
> > -----Original Message-----
> > From: [email protected] [mailto:[email protected]]
> > Sent: Monday, November 10, 2003 6:56 PM
> > To: [email protected]
> > Subject: [Nagios-devel] Different paging for different levels
> > Below is a post that I made to the nagios-users list over a
> > week ago. I
> > thought about it, and figured that nagios-devel would be the
> > better place
> > for it.
> > Summary: I'm thinking of some global config variable named
> > "force_hard_state_change_notification". It would be a
> > supplement for people
> > that have "notification_interval=0" to suppress periodic
> > notifications when
> > the hard state is the same not-OK state until recovery, but
> > DO want to know
> > about other hard state changes while not-OK (ie: a transition
> > from WARNING
> > to CRITICAL).
> > --- post follows ---
> > Whoops. Looks like my assessment was not 100% accurate.
> > When a service goes from WARNING to CRITICAL it _is_ a hard
> > state change.
> > The problem is that I have notification_interval=0 - which
> > means since it's
> > already sent single notification for a non-OK state (the
> > WARNING) it will
> > not send another notification for ANY OTHER non-OK state (the
> > CRITICAL).
> > What might be the "feature addition" that would make this
> > work for me would
> > be some option to enable some additional logic so that even if the
> > notification_interval=0, Nagios should ignore the time
> > interval and attempt
> > to send a immediate notification (assuming all the other checks like
> > downtime, flapping, etc. pass) whenever there's hard state change.
> > I'd like to work on adding this feature (I've spent a lot of
> > time reading
> > the source at this point) but I don't want to add logic where
> > it doesn't
> > belong. There's a lot of checks going on with
> > "check_service_notification_viability" in notifications.c, but there's
> > nothing about how to determine a hard state change. That's
> > done in checks.c
> > as part of "reap_service_checks". The "semi-psuedo code" for
> > my suggested
> > change to "check_service_notification_viability" would be:
> > /* dont notify contacts about this service problem again if
> > the notification
> > interval is set to 0
> > * unless forcing notification due to a hard state change */
> > if(svc->current_state!=STATE_OK && svc->no_more_notifications==TRUE){
> > if(force_hard_state_change_notification == FALSE ||
> > (svc->current_state!=svc->last_state &&
> > svc->current_attempt>=svc->max_attempts)) {
> > #ifdef DEBUG4
> > printf("\tWe shouldn't re-notify contacts
> > about this service
> > problem!\n");
> > #endif
> > return ERROR;
> > #ifdef DEBUG4
> > else {
> > printf("\tNotifications about hard state changes were
> > forced!\n"0;
> > #endif
...[email truncated]...
