Re: [Nagios-devel] RFC Proof of concept patch: Restarting embedded
Stanley Hopcroft wrote:
> Dear Sir,
> I am writing to thank you for your letter and say,
> On Wed, Oct 20, 2004 at 09:01:28PM -0500, Ethan Galstad wrote:
>>Following up on an old post that needs addressing...
>>The info from the Perl docs you provided earlier state that lost
>>memory can only be freed by stopping the process.
> Agreed.
>>Rather than
>>including this functionality in Nagios (which would be a bit kludgy),
>>I would recommend another approach (which is still hackish, but
>>better IMO)...
>>Use cron to periodically run a script that calls the check_vsz plugin
>>to determine the memory usage of the Nagios daemon. If the plugin
>>returns a critical state, restart Nagios using the init script.
>>Simple, but effective.
> Yes, this is a much better way (even periodic restarts from cron without
> checking mem use would be sufficient).
Umm.. How about the old-fashioned and cleaner way, using vfork(2) and
execve(2)?
OP5 AB www.op5.se
Lead Developer
