Re: [Nagios-devel] Possible nagiostats bug: Some MRTG data
> which nagiostat version do you use?
[nagios@nagsrv]$ /usr/local/nagios/bin/nagiostats --help
Nagios Stats 3.0rc2 =20
> >> Where AVGPSVSVCLAT is not translated.
> This a bug in Version 3.0rc1 and is fixed in the version 3.0rc2.
This should be 3.0rc2 (according to nagiostats --help), see above.
I will just ignore the doubled variable names on the external command
buffers, then, and use the set that works - thanks for the explanation
Best regards,
Steffen Poulsen
