[Nagios-devel] SQL support for object data?
Browsing around the source code of the 1.2 Nagios version I noticed that in objects.c there is a USE_XODMYSQL which seems to indicate a future support for MYSQL "object data support".
As I understand this, it would mean that there will be support for object data (host, service, command ...) configuration in mysql ?
Can(t find any reference to such feature so I just wondering if this is normal.
Regards,
