Re: [Nagios-devel] host_name and service_description examples
sean finney wrote:
> hi,
> On Mon, Jun 13, 2005 at 11:50:53PM -0500, Ethan Galstad wrote:
>>Nagios daemon, as well as archived log files, into a normalized MySQL
>>database (and possibly PostgreSQL later). It should provide a good
>>working base for new PHP/Perl interfaces for Nagios. The code is
>>still relatively new and under a good deal of development, but
>>something public should appear in the next month or two.
> does this mean there will in fact be mysql/pgsql support after all? i'd
> be happy to help out with what i can to further this.
As a module, I believe. The module api lets nagios work similar to gcc;
One module can load the config. The core does the work and another
module does the logging (similar to frontend, optimizer and backend).
Notifications is another thing that perhaps ought to be moved out to a
module. It's not strictly necessary on a slave-server sending passive
checks to a master host, and compartmentalizing code is most definitely
a Good Thing. Nagios will need to understand
include /etc/nagios-modules/*.cfg
or something similar though, for including short module-configurations
the way apache, php and the current linux ld does. A compile-time option
should work fine, but a configuration option would be better.
OP5 AB www.op5.se
Lead Developer
