--001636ed77e8345ab60475453d5a
Content-Type: text/plain; charset=ISO-8859-1
Hendrik,
how can I get the fix. Can you please provide me the patch or the cvs
link. Thanks in advance
On Tue, Oct 6, 2009 at 2:44 AM, Hendrik Baecker wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Am 02.10.09 19:42, schrieb shadih rahman:
> > All,
> > I have updated to ndoutils 1.48 and followed the instruction to do
> > so. Now I am seeing that I am missing output column data from both
> > nagios_hostchecks and nagios_servicechecks tables.
> Should be fixed in CVS Head.
> mysql> select * from nagios_servicechecks order by start_time desc limit
> 5 offset 0 \G
> *************************** 1. row ***************************
> servicecheck_id: 442
> instance_id: 1
> service_object_id: 3
> check_type: 0
> current_check_attempt: 4
> max_check_attempts: 4
> state: 1
> state_type: 1
> start_time: 2009-10-06 08:30:38
> start_time_usec: 132704
> end_time: 1970-01-01 01:00:00
> end_time_usec: 0
> command_object_id: 14
> command_args: 20%!10%!/
> command_line: /usr/local/nagios/libexec/check_disk -w 20% -c
> 10% -p /
> timeout: 60
> early_timeout: 0
> execution_time: 0
> latency: 0.132
> return_code: 0
> output: DISK WARNING - free space: / 1189 MB (16% inode=74%):
> long_output:
> perfdata: /=6087MB;6132;6899;0;7666
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (Darwin)
> iEYEARECAAYFAkrK5zoACgkQlI0PwfxLQjkOvgCePiYtsCj102M19PAEyb3i6vXs
> yr8Amwf7LCiM4fnW2JV4soQMILDhMpa2
> =NEdX
> -----END PGP SIGNATURE-----
> Come build with us! The BlackBerry® Developer Conference in SF, CA
> is the only developer event you need to attend this year. Jumpstart your
> developing skills, take BlackBerry mobile applications to market and stay
> ahead of the curve. Join us from November 9-12, 2009. Register now!
> http://p.sf.net/sfu/devconf
> Nagios-devel mailing list
> [email protected]
Cordially,
Shadhin Rahman
Content-Type: text/html; charset=ISO-8859-1
Hendrik,=A0=A0=A0=A0 how can I get the fix.=A0 Can you please provide m=
e the patch or the cvs link.=A0 Thanks in advanceOn Tue, Oct 6, 2009 at 2:44 AM, Hendrik Baecker =
<[email protected]&=
Hash: SHA1
> All,
> =A0 =A0I have updated to ndoutils 1.48 and followed the instruction to=
do
> so. =A0Now I am seeing that I am missing output column data from both
mysql> select * from nagios_servicechecks order by start_time desc limit=
5 offset 0 \G
=A0 =A0 =A0servicecheck_id: 442
=A0 =A0 =A0 =A0 =A0instance_id: 1
=A0 =A0service_object_id: 3
=A0 =A0 =A0 =A0 =A0 check_type: 0
=A0 max_check_attempts: 4
=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0state: 1
=A0 =A0 =A0 =A0 =A0 state_type: 1
=A0 =A0 =A0 =A0 =A0 start_time: 2009-10-06 08:30:38
=A0 =A0 =A0start_time_usec: 132704
=A0 =A0 =A0 =A0 =A0 =A0 end_time: 1970-01-01 01:00:00
=A0 =A0 =A0 =A0end_time_usec: 0
=A0 =A0com
...[email truncated]...
