Hi there,
Yesterday I wanted to redo my patch for same-host service dependencies
and add a master switch in the main config file so that by default it
won't allow to omit the dependent_host*_name parameter.
I started by building a test config... I just couldn't manage to create
a service dependency. Even the simplest and straightforward
servicedependency definition just wouldn't work. To be on the safe side
I even checked one of my prod config with CVS HEAD after removing
same-host svc deps and making it v3-compatible with no luck either. It
would complain on every servicedependency definitions.
Looking at the code I couldn't really tell what was wrong as I do not
yet understand fully how Nagios parses the config.
Also worth noting is some code for same-host depedencies. It's so
incomplete I just can't understand how it got there!?!
$ nl xdata/xodtemplate.c|grep -iC3 same.host
3952 char *host_name=NULL;
3953 char *service_descriptions=NULL;
3954 int first_item=FALSE;
3955 int same_host_dependency=FALSE;
3956 #ifdef NSCORE
3957 char *temp_buffer=NULL;
3958 #endif
4365 /****** PROCESS SERVICE DEPENDENCY DEPENDENT
HOSTS/HOSTGROUPS/SERVICES *****/
4366
for(temp_servicedependency=xodtemplate_servicedependency_list;temp_servicedependency!=NULL;temp_servicedependency=temp_servicedependency->next){
4367 /* ADDED 02/04/2007 - special case for "same
host" dependencies */
4368
if(temp_servicedependency->dependent_host_name==NULL &&
temp_servicedependency->dependent_hostgroup_name==NULL){
4369 if(temp_servicedependency->host_name)
4370
temp_servicedependency->dependent_host_name=(char
*)strdup(temp_servicedependency->host_name);
As you can see there's a boolean for same host deps that isn't used
(should be set to TRUE where it duplicates host_name to
dependent_host_name and also used later to avoid most duplications to
occur. Also hostgroup_name ist't duplicated so I think it wouldn't work
with hostgroup_name.
Thomas
