I created a softlink of /usr/local/sys/uio.h in /usr/local/include and
changed the lib to /usr/lib/mysql. That got it past the compilation.
David
-----Original Message-----
Sent: Tuesday, March 05, 2002 12:22 PM
To: 'David Edward Shapiro'
Subject: RE: [Nagios-devel] problem compiling nagios-1.0a6
Shouldn't the ./configure use --with-mysql-lib=/usr/lib/mysql rather than
/var/lib/mysql/mysql?
Where it says change it to and see what happens when you
run make again.
Ewan
> From: David Edward Shapiro [mailto:[email protected]]
> Sent: 05 March 2002 16:53
> To: '[email protected]'
> Subject: [Nagios-devel] problem compiling nagios-1.0a6
> Hello,
> I used cvs to download the lastest nagios. I ran configure with the
> following options:
> ./configure --with-mysql-xdata --with-template-objects
> --with-mysql-lib=/var/lib/mysql/mysql --with-mysql-inc=/usr/includ
> e/mysql --enable-webhelp --enable-embedded-perl --with-perlcache
> --with-ping-command=/usr/local/sbin/fping
> None of the binaries are getting made. (I downloaded and installed
> binutils-2.11-2)
> During the make I see ld collect2 errors for nagios and
> things like cgi.
> I see in config.status the following errors:
> onfigure
> configure
> configure: failed program was:
> #line 1240 "configure"
> #include "confdefs.h"
> #include > > I did a locate on uio.h and found:> >/usr/include/linux/uio.h> /usr/include/bits/uio.h> /usr/include/sys/uio.h>/usr/i386-glibc21-linux/include/bits/uio.h>/usr/i386-glibc21-linux/include/linux/uio.h>/usr/i386-glibc21-linux/include/sys/uio.h> > Do I need to set an environmentvaribable to find uio.h? > Which uio.h should> it use?> > configure
> /usr/lib/mysql:
> libmysqlclient.so.10 -> libmysqlclient.so.10.0.0
> How can I get around these errors?
> David
> David E. Shapiro
> Senior Unix Admin
> BTi - the future of communications
> Nagios-devel mailing list
> [email protected]
Original poster: wan Leith [mailto:[email protected]
