Re: [Nagios-devel] Nagios3 CVS - Notification State (null) in Log
Thomas Stolle wrote:
> Dear List,
> today I updated my test system to the newest Nagios3 CVS.
> I generated a Critical state by submitting a passiv check result.
> The Service changed his state to critical and a notification (critical
> state) was send but in the nagios.log and caused by this in the
> Nagios-Giu, the notification state is (null) -> Unknown
> Here you can see a part of nagios.log
> [1193838747] EXTERNAL COMMAND:
> PROCESS_SERVICE_CHECK_RESULT;de008ps1;Backup;2;Test Message|
> [1193838750] PASSIVE SERVICE CHECK: de008ps1;Backup;2;Test Message
> [1193838750] SERVICE ALERT: de008ps1;Backup;CRITICAL;HARD;2;Test Message
> [1193838750] SERVICE NOTIFICATION:
> rt20;de008ps1;Backup;(null);notify-by-email;(null)
> Best Regards
> Thomas
Thanks for the note. This was caused by a change in the macro code
logic. I'll get a patch into CVS in a few minutes...
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
