[Nagios-devel] NSCA 2.4 patch
Here is a patch a buddy of mine put together which allows the nsca.cfg
for the nsca daemon to allow hostnames, along with IPs, in the
allowed_hosts field. It uses the gethostbyname and the inet_ntoa system
functions.
The patch was coded to work the FreeBSD ports version of nsca-2.4.
However, even though the patch is not portable, the modification itself
should be.
Author :: Brian Gillis
Patch :: http://www.thegillis.net/examples/nagio ... llis.patch
Installation ::
#> cd /usr/ports/net-mgmt/nsca
#> wget http://www.thegillis.net/examples/nagio ... llis.patch
#> make extract
#> patch -p1 make install
- Justin Kulikowski
[ http://www.jpk236.com ]
