Re: [Nagios-devel] RE: [Nagios-users] status log documentation?
On Mon, 15 Sep 2003, Skip Montanaro wrote:
> Note to the folks working on Nagios 2.0: It would be real nice if you made
> the log file format an actual CSV file (a semicolon delimiter is fine).
> You're about 90% of the way there as it is. For the most part, all you need
> to do is make sure each bit of data is in its own field and make sure the
> delimiter (semicolon in this case) is properly quoted wherever it appears.
> For example, instead of
Nagios 2 should be able to suport a number of formats with the NXE add-on
nxe.sf.net
-sg
