I just needed to look a bit higher up, basically the write_to_syslog is bei=
ng called from both logging functions, and the use_syslog option is checked=
only in the write_to_syslog function as a sort of bail out point.
That makes sense, but I wanted the option to mean something a little differ=
ent, so now I've modified the write_to_all_logs and write_to_all_logs_with_=
timestamp to check for use_syslog and only write out the regular log file i=
f use_syslog is false.
This way I don't double my logging overhead. Now use_syslog means use_sysl=
og only
Sincerely,
Steve
________________________________________
Sent: Tuesday, June 02, 2009 8:53 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Purpose of use_syslog
Odd, when I read it, it looked like use_syslog only used the syslog facilit=
y, but it is a bit confusing isn't it.
I'm going to take a closer look.
Sincerely,
Steve
Sent: Monday, June 01, 2009 8:34 PM
To: [email protected]
On Mon, 1 Jun 2009 09:51:48 -0600, "Steven D. Morrey"
wrote:
>Hi Everyone,
>I've decided to take a long hard look at my config files and have a questi=
on about some of the options.
>In particular I'd like a little more information on the use_syslog option.
>If enabled does this option use syslog instead of, or in addition to the i=
nternal log?
Documentation doesn't make it entirely clear, but a quick peek into
base/logging.c hints that use_syslog means it will log to both when
set to 1, at least that's how I'm reading the code.
Jonathan Angliss
OpenSolaris 2009.06 is a cutting edge operating system for enterprises
looking to deploy the next generation of Solaris that includes the latest
innovations from Sun and the OpenSource community. Download a copy and
enjoy capabilities such as Networking, Storage and Virtualization.
Go to: http://p.sf.net/sfu/opensolaris-get
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you are not the =
intended recipient, please contact the sender by reply email and destroy al=
l copies of the original message.
[email protected]
Original poster: on Angliss [[email protected]
