> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3120827605_13153566
Content-type: text/plain; charset="US-ASCII"
Content-transfer-encoding: 7bit
After upgrading to Solaris 8, we discovered that any service/host checks
that were run with parentheses in the command line failed CRITICAL, with (No
output!).
Apparently, /bin/sh suddenly started caring about parens in command lines
after the upgrade.
For not quoting our argument strings, we are sufficiently chastened.
In the process of figuring this out, we added a "log_executions"
configuration directive, which will echo the check commands to nagios.log as
they are being run. It was invaluable to us, and we hope it finds its way
into CVS.
The patch is just the output of "cvs diff" in nagios/base, since the exact
rules for submitting patches are unclear.
The patch doesn't capture the following line in nagios.h, since it's subst'd
during make:
#define DEFAULT_EXECUTION_LOGGING 0 /* log execution events? 1=yes,
0=no */
Hope you find this as useful as we did.
-Gunnar
PS - ObFeatureRequest: It would be wonderful if STDERR and/or STDOUT could
be redirected from plugins to a file, to help debugging and tracing.
Content-type: application/octet-stream; name="log_executions.patch"
Content-disposition: attachment
Content-transfer-encoding: base64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--B_3120827605_13153566--
