Re: [Nagios-devel] [patch] Fix compiler warnings
--Yylu36WmvOXNoKYn
Content-Disposition: inline
On Wed, Sep 22, 2010 at 08:49:20AM +0200, Michael Friedrich said:
> I don't think this should be treated like this in regard of checking
> data if NULL. Currently the return code not checked for OK|ERROR when
> calling the function, but each call provides a void* typecasted svc or
> hst for the data function param. In regard of continuous behavior I
> would recommend changing that the way I proposed before - by returning
> ERROR instead of OK, if data is NULL. see broker_host|service_check
> for examples on returning return_code. It won't affect anything right
> now, just keeping source clean.
You are quite likely correct. The calls to this that I could find
(although I may have missed some) appear to call it in void context, so
I didn't see much benefit in making it return ERROR instead of OK. I
agree that a better patch would make it return ERROR and also make the
callers always check the return code.
Cheers,
--=20
| Stephen Gran | Steal this tagline. I did. |
| [email protected] | |
| http://www.lobefin.net/~steve | |
--Yylu36WmvOXNoKYn
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: Digital signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)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=47FH
-----END PGP SIGNATURE-----
--Yylu36WmvOXNoKYn--
