[Nagios-devel] DEFAULT_CGI_CONFIG_FILE
Searching through the nagios/cgi sources you can find the C define
"DEFAULT_CGI_CONFIG_FILE" throughout the cgi code. Unfortunately this
is not only the default config file but the only config file. I need
to change the config file at runtime, not compile time, and with nagios
this is impossible.
Fortunately, it shouldn't be too hard to fix. Just let it get the
configuration from another source, perhaps an Apache configuration, so
that it can be configured at runtime just like the rest of nagios.
--arley
