Re: [Nagios-devel] Ready Only User Suggestion
Chris Woollard wrote:
> I don't think the concept of a ready only user exists at the moment in
> Nagios, and i think it would be particularly useful.
> The reason I ask is because I would like to provide a few of my end
> users with a username and password to login to Nagios. Preferably in a
> read only state, that doesn't allow anything to be changed or even to
> hide the menu options to change any options.
> At the moment I have created users that only display specific host /
> service data but that user can change options eg. config downtime,
> disable notifications etc.
> If this does already exisit. How do I do it?
It doesn't exist and it won't be added until the new gui is ready to
fly. If you submit a patch for it it'll most likely be turned down (the
changes would be fairly extensive), but you can always try. I don't
think anyone else will though, so you'd better whip up your mad c
programming skills and get to work.
OP5 AB www.op5.se
Lead Developer
