Re: [Nagios-devel] Nagios 1.2 fast IO-patch
This patch is a bit old, but I've just gotten around to testing it on
the 2.0 code. From what I can tell, there's no measureable
difference with or without the patch. I tested three different
reporting ranges ("today", "this year", and "last year") on two
separate boxes. Both boxes are RedHat 7.2 running kernel-2.4.20-
20.7.
One box is a PII 400 w/ 220 MB RAM, an 8 GB SCSI drive and 45 hosts
in the report. The other is a PII 300 w/ ~200 MB RAM, an 8 GB SCSI
drive and 15 hosts in the report.
Report generation times were within 5% of each other on both machines
when tested w/ and w/o the patch (sometimes the patches version was
actually slightly slower than the nonpatched code). Average report
times for "today", "this year" and "last year" are approx: 1.25 sec,
6.2 sec, and 7.7 sec.
Perhaps the SCSI drives are doing a better job at predictive reads
than the IDE drives you tested. Not sure. Or perhaps its something
else. For the record, I have not tested this against 1.2, but I
wouldn't think the results would be much different. Anyone else
tried this patch out? If so, what were your findings?
On 22 Mar 2004 at 17:07, Andreas Ericsson wrote:
> Hi all.
> I wrote this patch the other day when I was juggling with automating
> reports (avail.cgi), and I noticed that parsing the files alone took 8
> seconds, even though it was less than 3MB of data. The solution was to
> rewrite the read_line() function in cgiutils.c to utilize larger
> read()-buffers and thus allow for IO bursting. With this patch applied
> execution time went down to 0.7 seconds.
> It also solves the problem with not-newline-terminated rows not being
> read in the configuration files (discussed earlier).
> The only drawback is that it will take forever to parse files that are
> larger than you have physical RAM available (the kernel will utilize
> the swap-space), and will fail completely (pretending the file is
> empty) if the file is larger than the physical AND virtual RAM
> combined. However, considering that it already takes forever even with
> relatively small files, this shouldn't be a problem.
> This patch is also available for 2.0a1, but I haven't had time to test
> it to any extent with that release.
> Tested on Openwall GNU/*/Linux, kernel 2.4.24-ow1 running on;
> a) Celeron 2.0Ghz with 256MB RAM and a single 40GB IDE-disk.
> b) Pentium 4 HT 2.8Ghz with 512MB RAM and dual 120GB IDE-disks with
> software RAID-mirroring. c) Dell Inspiron PIII 866Mhz with 256MB RAM
> and a single 20GB IDE-disk.
> Cheers,
> Sourcerer / Andreas Ericsson
Ethan Galstad,
Nagios Developer
Email: [email protected]
