[Nagios-devel] chech_http on a no-standard port
------=_NextPart_000_00A5_01C468D4.D80F66E0
Content-Type: text/plain;
charset="us-ascii"
Message
Hi guys!
Do you know if is it possible to write in the "Status information"
(present in the Service State Information) the port number where I am
performing the check?
I have the problem only when the "Current Status" is NOT OK, because the
message I read is: "Socket timeout after 10 seconds".
I have same problem with check_tcp command.
If it is necessary, I will modify the source files .... but I don't know
which ones !
Regards
Marco
Content-Type: text/html;
charset="us-ascii"
Message
Hi=20
guys!
Do=20
you know if is it possible to write in the "Status information" =
(present in=20
the Service State Information) the port number where I am performing =
the=20
check?
I have the problem only when the "Current Status" is NOT OK, =
because=20
the message I read is: "Socket timeout after 10 seconds".
I have same problem with =
check_tcp=20
command.
If=20
it is necessary, I will modify the source files .... but I don't know=20
which ones !
Regards
Marco
------=_NextPart_000_00A5_01C468D4.D80F66E0--
