Re: [Nagios-devel] [PATCH] core: Don't free the lock file path too
Will apply. Thanks.
On 2013-05-22 10:41, Robin Sonefors wrote:
> It's used after the main loop ends in the main function to remove the
> lock file once we're shut down.
> As the variable was already freed and pointed to NULL, unlink would not
> remove the lock file, but instead return EFAULT. This is not how daemons
> are supposed to behave.
> Signed-off-by: Robin Sonefors
> base/utils.c | 1 -
> 1 file changed, 1 deletion(-)
> diff --git a/base/utils.c b/base/utils.c
> index 5e038cb..362e683 100644
> --- a/base/utils.c
> +++ b/base/utils.c
> @@ -2902,7 +2902,6 @@ void free_memory(nagios_macros *mac) {
> my_free(command_file);
> mac->x[MACRO_COMMANDFILE] = NULL; /* assigned from command_file */
> my_free(log_archive_path);
> - my_free(lock_file);
> for (i = 0; i my_free(macro_user);
OP5 AB www.op5.se
on peace.
