I'm using passive plugins to check interfaces, cpu and memory usages
on a regular basis (from crontab).
The plugins are written in perl, and submit check results with Nagios::Cm=
d
which works great.
The only problem is: If for e.g. an interface is critical, the plugin
submits a CRITICAL check result every 5 min to Nagios.
Nagios in turn is not honoring the notification_interval (which is
set to 120), and sends out Notifications every time a result is
submitted - this can be very uncomfortablly with notifications as SMS
Is there a way to get Nagios honoring notification_interval with
passive checks ?
Best Regards,
Andreas
--=20
Andreas Wassatsch
LPIC-2
using Linux since 0.99pl10
