Re: [Nagios-devel] patch for nagios 3rc1 - update
--------------060509010606040509060200
Hello again.
I'm sorry to do this, as it's rather embarrassing, but I've got a small
update to the patch I submitted earlier. This version has two
differences from the first patch I sent:
1. Most of the check_results_info structure initialization has been
moved back above the broker INITIATE call. I found that I needed to use
some of the fields in that global structure from within my INITIATE
handler - mostly this is data that a proper handler needs to track for
final results submission, but it's not passed any other way. I'll send
another message later to discuss this in more detail.
2. I actually fixed the minor memory leaks that I mentioned in my
previous note. ;) I guess I forgot to put those in before creating the
patch.
Thanks for your patience,
John
John Calcote wrote:
> Hi!
> I've recently joined the Distributed Nagios eXecutor (DNX) team (Oct
> '07), and have just gotten around to porting DNX over to Nagios 3.
> I've been looking at nagios-3.0rc1, and I can see that a new type of
> NEBCALLBACK event has been added -
> NEBTYPE_SERVICECHECK_ASYNC_PRECHECK. I also note that the run-time
> semantics of NEBTYPE_SERVICECHECK_INITIATE have been modified between
> Nagios 2.x and 3.x. That is, the INITIATE check no longer honors the
> handler's return code.
> I have a small wish in the form of a patch to nagios-3.0rc1 that I
> would like to suggest. I hope you'll find this change reasonable. The
> patch simply moves the call to broker_service_check(
> NEBTYPE_SERVICECHECK_INITIATE, ... ) above the code that configures
> the temporary check output file and check_results_info structure. This
> puts the broker call in a similar relative position in 3.x code as in
> 2.x code, except for the check_result_info structure initialization,
> which didn't really have to be done before the broker call anyway. In
> addition, I moved the code that honors the CALLBACKOVERRIDE return
> value down to the INITIATE check, but left the code that honors the
> newer CALLBACKCANCEL in the ASYNC_PRECHECK check.
> This grants two advantages that I can see:
> 1. It makes Nagios 2.x modules more portable because Nagios 3.x would
> honor the same NEB module return values they did in Nagios 2.x code
> for the INITATE check. In addition, it provides the useful ability for
> Nagios 3.x modules to cancel a check in the PRECHECK handler where it
> makes sense to do very little preprocessing before canceling the
> check; cancelling the check in the INITIATE handler is less efficient.
> 2. NEB modules that want to handle the check themselves with the
> CALLBACKOVERRIDE return value are going to have trouble processing
> macros the same way that Nagios does, unless Nagios provides some API
> routines to do it for them. It makes more sense (IMHO) to have the
> CALLBACKOVERRIDE honored by the INITIATE check, rather than the
> I'm hoping (if you all approve of this change), that we can get it
> into the Nagios 3.0 code base before 3.0 ships. Would it be too late
> for that?
> Regards,
> John
> PS. The patch also fixes a minor error path memory leak, where the
> raw_command string was not being freed in case of an out-of-memory
> condition while allocating the processed_command buffer.
name="nagios-3.0rc1-dnx.patch"
Content-Disposition: inline;
filename="nagios-3.0rc1-dnx.patch"
diff -Naur nagios-3.0rc1/base/checks.c nagios-3.0rc1-patched/base/checks.c
--- nagios-3.0rc1/base/checks.c 2007-12-12 11:39:46.000000000 -0700
+++ nagios-3.0rc1-patched/base/checks.c 2008-01-20 20:10:06.000000000 -0700
@@ -380,11 +380,6 @@
*preferred_time+=(svc->check_interval*interval_length);
return ERROR;
- /* neb module wants to override the service check - perhaps it will check the service itself */
- /* NOTE: if a module does this, it has to do a lot of th
...[email truncated]...
