Fedora 14 2.6.35.6-45.fc14.i686
I am attempting to install nagios on a Fedora 14 box. I've d'loaded the latest version of nagios 3.2.3 and the plugins 1.4
When I perform the command: ./configure --with-command-group=nagcmd (as it says in the install document) i had no errors and it says the install directory is /user/local/nagios
General Options:
Nagios executable: nagios
Nagios user/group: nagios,nagios
Command user/group: nagios,nagcmd
Embedded Perl: no
Event Broker: yes
Install ${prefix}: /usr/local/nagios
Lock file: ${prefix}/var/nagios.lock
Check result directory: ${prefix}/var/spool/checkresults
Init directory: /etc/rc.d/init.d
Apache conf.d directory: /etc/httpd/conf.d
Mail program: /bin/mail
Host OS: linux-gnu
Web Interface Options:
HTML URL: http://localhost/nagios/
CGI URL: http://localhost/nagios/cgi-bin/
Traceroute (used by WAP): /bin/traceroute
Review the options above for accuracy. If they look okay,
type 'make all' to compile the main program and CGIs.
but when I attempt to 'make all' I get the following errors:
make all
cd ./base && make
make[1]: Entering directory `/home/linuxguy/Downloads/nagios-3.2.3/base'
make[1]: *** No rule to make target `../include/locations.h', needed by `broker.o'. Stop.
make[1]: Leaving directory `/home/linuxguy/Downloads/nagios-3.2.3/base'
make: *** [all] Error 2
[root@01ad-g7gwg41 nagios-3.2.3]# make all: make install; make install-init; make install-config; make install-commandmode; make install-webconf
make: *** No rule to make target `all:'. Stop.
/usr/bin/install -c -m 755 -d -o root -g root /etc/rc.d/init.d
/usr/bin/install -c -m 755 -o root -g root daemon-init /etc/rc.d/init.d/nagios
*** Init script installed ***
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/etc
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/etc/objects
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/nagios.cfg /usr/local/nagios/etc/nagios.cfg
/usr/bin/install: cannot stat `sample-config/nagios.cfg': No such file or directory
make: *** [install-config] Error 1
/usr/bin/install -c -m 775 -o nagios -g nagcmd -d /usr/local/nagios/var/rw
chmod g+s /usr/local/nagios/var/rw
*** External command directory configured ***
/usr/bin/install -c -m 644 sample-config/httpd.conf /etc/httpd/conf.d/nagios.conf
/usr/bin/install: cannot stat `sample-config/httpd.conf': No such file or directory
make: *** [install-webconf] Error 1
As the install document goes on it says there should be a contacts.cfg inside the /usr/local/nagios/etc/objects directory, but there is nothing inside the directory.
Inside the nagios/etc directory the only thing there is objects, but there is nothing inside the object directory.
Any info on my problem would be greatly appreciative and I can give more info if needed.
Install troubles with Nagios + Fedora 14
Re: Install troubles with Nagios + Fedora 14
This may not be updated for Fed 14, but it might help you find the issue:
http://nagios.sourceforge.net/docs/3_0/ ... edora.html
Fedora 14 already bundled with Nagios and its Plugin. I just simply using "Add/Remove program" inside Fedora for installation. Fast and simple.
David
David
fustigator
I followed this to the letter and got exactly the same problem described above. I also notice that my /usr/local/nagios/bin folder was empty.
Rgds,
Dan
Rgds,
Dan
