--MP_/46TLYwNofx6AQ7iRzJR5st+
Content-Type: text/plain; charset=US-ASCII
Content-Disposition: inline
I was about to report this issue but it looks like someone beat me to
it. However unless I'm mistaken the call to clear_volatile_macros() is
redundant anyway, so an updated patch is attached.
Cheers,
Adam James, Transitiv Technologies Ltd.
Business Critical Support and Services for Open Source Software.
T: 0203 384 7207
E: [email protected]
W: http://www.transitiv.co.uk/
Content-Type: text/x-patch
filename=0001-core-Initialize-notification-macro-before-access.patch
From 6882f89244c829561c677d45cbe55e818e0f40e5 Mon Sep 17 00:00:00 2001
Date: Mon, 18 Jul 2011 19:36:18 +0100
Subject: [PATCH] core: Initialize notification macro before access
This patch fixes a bug created as a result of the patch to move away
from the use of global macros when sending notifications (r1744).
The nagios_macros struct was defined but never initialised and then
passed to clear_volatile_macros(), resulting in a segfault due to an
attempt to free a pointer with a garbage value.
The fix means that the call to clear_volatile_macros() is now redundant
so it has been removed.
base/notifications.c | 4 +---
1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/base/notifications.c b/base/notifications.c
index f053f27..a6e56b3 100644
--- a/base/notifications.c
+++ b/base/notifications.c
@@ -1037,9 +1037,6 @@ int host_notification(host *hst, int type, char *not_author, char *not_data, int
return OK;
- /* clear volatile macros */
- clear_volatile_macros_r(&mac);
log_debug_info(DEBUGL_NOTIFICATIONS,0,"Notification viability test passed.\n");
/* should the notification number be increased? */
@@ -1057,6 +1054,7 @@ int host_notification(host *hst, int type, char *not_author, char *not_data, int
log_debug_info(DEBUGL_NOTIFICATIONS,2,"Creating list of contacts to be notified.\n");
/* create the contact notification list for this host */
+ memset(&mac, 0, sizeof(mac));
create_notification_list_from_host(&mac, hst,options,&escalated);
#ifdef USE_EVENT_BROKER
1.7.3.4
--MP_/46TLYwNofx6AQ7iRzJR5st+--
