[Nagios-devel] NEBCALLBACK_SERVICE_STATUS_DATA callback being
Hello all,
I'm attempting to write a NEB module that will enable forwarding of
service state transitions to another NMS platform. I'm registering
for NEBCALLBACK_SERVICE_STATUS_DATA, but my callback is being invoked
twice for each status update, with identical timestamp, type code and
identical current_state and last_state in the (service *)
(data->object_ptr). There's only a single event type associated with
this hook (NEBTYPE_SERVICESTATUS_UPDATE). Is this normal behavior for
this hook (and if so, what is the reasoning behind this, or is there
at least a difference between the 2 invocations that I can use to
filter on)? I'd like to avoid sending/clearing the same alarm twice
in a row.
TIA,
James
