--0__=i93uEKy5CauDJ782nX7FonjFW5rCPW1C6TE4Z267iDUai7gL0zbIJod8
Content-type: text/plain; charset=iso-2022-jp
Content-Disposition: inline
Dear Sumit san,
Thank you for your advise and now I've confirmed about your advise.
I tried to do "su nagios" and my script "notify-to-keiko-chan", it worked fine,
alarm light was turn-on.
So again I tried to plug off LAN line for target host and watch event log of
Nagios.
Nagios says some HOST ALART and EVENT HANDLER messages about terget host LAN
connection, I looked following message on the event log at last;
[09-08-2005 10:18:21] SERVICE ALERT: local1-ATX135;PING;CRITICAL;HARD;1;CRITICAL
- Host Unreachable (172.17.0.150)
[09-08-2005 10:18:21] HOST EVENT HANDLER:
local1-ATX135;DOWN;HARD;10;notify-to-keiko-chan
[09-08-2005 10:18:21] HOST ALERT: local1-ATX135;DOWN;HARD;10;CRITICAL - Host
[09-08-2005 10:18:18] HOST EVENT HANDLER:
local1-ATX135;DOWN;SOFT;9;notify-to-keiko-chan
[09-08-2005 10:18:18] HOST ALERT: local1-ATX135;DOWN;SOFT;9;CRITICAL - Host
But alarm light didn't work. I seem to look like it has no problem about
permission of my script "notify-to-keiko-chan" and user account "nagios".
My Nagios environment is wrong for Nagios 2.0B4? Do I forget to check anything?
It's better to down grade from FC4 to FC3 for Nagios server? Please advise me.
Thank you lots of your help,
Takashi Maruyama
Aucnet Inc.
IT Department
"Sumit Malhotra" 2005/09/07 18:51:30
$B08@h(B: Takashi Maruyama/A/AUCNET@AUCNET, [email protected]
cc:
$B7oL>(B: RE: [Nagios-devel] Behavior of event handler - doesn't work alarm light
Content-type: text/plain; charset=us-ascii
I can only think of permissions issues. Try doing a su nagios and
running the same test.
/usr/local/nagios/libexec/eventhandlers/notify-to-keiko-chan DOWN HARD
Best of luck !
Thanks.
Sumit Malhotra
Data Armor
-----Original Message-----
[mailto:[email protected]] On Behalf Of Takashi
Maruyama
Sent: Wednesday, September 07, 2005 3:04 PM
To: [email protected]
Subject: [Nagios-devel] Behavior of event handler - doesn't work alarm
light
Dear sir,
I'm testing watching system by Nagios 2.0B4 with Fedora Core 4.
It work fine to watch ping check of some hosts and routers. Then, I
modify
configuration file since I try to make notify by alarm light when Nagios
detect
host or router error event.
But it doesn't work and current configuration is as follows;
[minimal.cfg, from sample configuration file for hosts, services]
# [ command section ]
# Notify alarm for Keiko-chan mini
command_name notify-to-keiko-chan
command_line
/usr/local/nagios/libexec/eventhandlers/notify-to-keiko-chan $HOSTSTATE$
$STATETYPE$ $HOSTATTEMPT$
# [ host section ]
use generic-host
host_name local1-ATX135
alias test local
address 172.17.0.150
max_check_attempts 10
event_handler notify-to-keiko-chan
notification_interval 120
contact_groups admins
[notify-to-keiko-chan, sh script for alarm light ]
#!/bin/sh
echo $1, $2
case "$2" in
HARD)
case "$1" in
UP)
DOWN)
rsh 172.17.20.1 -l root RLY2 TurnOn -p dn1000
esac
esac
exit 0
1. "notify-to-keiko-chan" script work fine individually. For example,
"notify-to-keiko-chan DOWN HARD"
2. On nagios.log, it seem to see work fine, that is Nagios detect error
and do
event handler when host has error.
[09-06-2005 22:03:21] HOST EVENT HANDLER:
[09-06-2005 22:03:21] HOST ALERT: local1-ATX135;DOWN;HARD;10;CRITICAL -
Host
[09-06-2005 22:03:18] HOST EVENT HANDLER:
3. Our Nagios install by tarball on www.nagios.org.
4. Also our alarm l
...[email truncated]...
