RE: [Nagios-devel] restrict check_disk to local mounts
On Fri, 2003-07-11 at 12:44, Skip Montanaro wrote:
> Ton> Thanks for the patch Skip, but the latest CVS version of check_disk
> Ton> allows an option to ignore types of filesystems, such as CDROMs.
> Cool. I've been using 1.3.0. Guess it's time to upgrade...
1.3.99 is development. You can get it and run. Bug reports and patches
gratefully accepted.
But things may change (Most of the user-visibale changes have already
happened, but there are no promises...)
Karl
