RE: [Nagios-devel] Availability report bug
Apologies for that! Closer inspection shows you did mention the custom
report period.
What result do you get? If I choose April 1 2003 to April 30 2003, the next
page shows me:
04-01-2003 00:00:00 to 05-01-2003 00:00:00
Duration: 30d 0h 0m 0s
which looks correct.
Ton
> -----Original Message-----
> From: Mikko Kaipila [SMTP:[email protected]]
> Sent: Wednesday, May 28, 2003 12:27 PM
> To: Voon, Ton
> Cc: [email protected]
> Subject: RE: [Nagios-devel] Availability report bug
> I have noticed that. There are still wrong time duration. And this
> problem only concerns time duration 1-30th on April!
> On Wed, 2003-05-28 at 13:53, Voon, Ton wrote:
> > In the drop down box for Report Period, you need to select * CUSTOM
> REPORT
> > PERIOD *. Then the figures you entered will be used.
> > I don't think this is a bug, but it could certainly be better (multiple
> > forms on a page maybe). As Ethan is changing the CGIs for 2.0, probably
> not
> > worth amending now.
> > > Sent: Wednesday, May 28, 2003 10:57 AM
> > > To: [email protected]
> > > Subject: [Nagios-devel] Availability report bug
> > > Hi!
> > > There are some bug in the availibility report!
> > > Example step by step:
> > > 1) choose availability report for some service
> > > 2) choose custom report period
> > > 3) choose time duration 1-30th on April
> > > 4) notice the time duration top of the page! At least I get the time
> > > duration, that is not the same that I chosen. The very same "bug"
> seems
> > > to be both version of Nagios 1.0 and 1.0b6. Naturally the results of
> the
> > > specified service for whole April are not correct.
> > > It seems that all the other custom report periods works fine.
This private and confidential e-mail has been sent to you by Egg.
The Egg group of companies includes Egg Banking plc
(registered no. 2999842), Egg Financial Products Ltd (registered
no. 3319027) and Egg Investments Ltd (registered no. 3403963) which
carries out investment business on behalf of Egg and is regulated
by the Financial Services Authority.
Registered in England and Wales. Registered offices: 1 Waterhouse Square,
138-142 Holborn, London EC1N 2NA.
If you are not the intended recipient of this e-mail and have
received it in error, please notify the sender by replying with
'received in error' as the subject and then delete it from your
mailbox.
