Re: [Nagios-devel] Logging API revamp
Ethan Galstad wrote:
> Andreas Ericsson wrote:
>> So, I started looking into revamping the event queue logic, but ended up
>> with a migraine from the cumbersome way logging is done, so I decided to
>> try doing something about it, and the attached 3-patch series is the
>> result from it.
>> It compiles alright, both for nagios and the cgi's. I haven't done much
>> in the way of checking past that though, so testing would be welcome.
>> Given that the patches don't change much in the way of logic, they
>> shouldn't really affect anything in significant way.
> Patch has been applied with a fix in the logit function that cased a
> segfault.
Ugh. That's what I get for eye-pasting code :-/
> I'll be applying another patch shortly to rename the logit()
> function to something closer to how the other funcs are named...
I was nearly sure you would ;-)
OP5 AB www.op5.se
