Your solution is a lot cleaner than my workaround in subst.in
I thinks thats the way to go..
-sg
On Thu, 2 May 2002, Douglas E. Warner wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Heh. My bad. I forgot that you use 'patch' with a 'diff'.
> I've attached the diff for check_ntp; but I just attached the entire
> mini_epn.c since I reformated spacing to be more consistent. Other than
> that, my changes where minor.
> - -Doug
> On Thursday 02 May 2002 10:56, Douglas E. Warner wrote:
> > This is a carry-over from the nagios-users mailling list for the thread
> > titled 'embedded perl setup'.
> > I've hacked mini_epn.c so it accepts longer command lines and check_ntp so
> > that it will work with mini_epn. Let me know whether you would like
> > patches or if diffs are fine.
> > -Doug
> Douglas E. Warner Network Engineer
> CTI/PAdotNET http://www.pa.net +1 717 503 9006
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.0.6 (GNU/Linux)
> Comment: For info see http://www.gnupg.org
> iD8DBQE80V0KJV36su0A0xIRAvKsAKDibgZrX0W/kFWvZYXvofei1GKpagCg+Pqj
> HIRSHVkimXFlYFxIoXkgWG8=
> =r8+c
> -----END PGP SIGNATURE-----
